could you be more specific please?
I am having the same problem with my new Ultimaker 3 and Cura 3.6. I'm using Ultimaker Silver PLA in extruder 1 and Natural PVA in extruder 2. Cura recognizes the Ultimaker 3 and detects that it has Extruder 1 and Extruder 2.
Both materials are selected correctly in the Cura sidebar but there is a warning saying to "Check Compatability". These materials are valid in the chart on the Ultimaker website.
I have a simple STL imported that is small and in the center of the build plate. I am using "Recommended" as my Print Setup.
I've not been able to figure out what is wrong and need help.
Edited by essentiaI found the cause of my problem. I needed to set the print core on extruder 2 to BB 0.4. It somehow got set to AA, which is wrong. Now I can slice and print.
hi,
yeah it worked for me to, I set the print core on extruder 1 to AA 0.4.
thanks !
ahoeben 1,968
Check the configuration of the other extruder.
