What is the value of the "Initial layer horizontal expansion" ?
My first thought was also that you have "initial layer horizontal expansion" set to something greater than zero. I usually set that to a *negative* value to get rid of elephants foot. Setting it to a positive value will just make the foot worse.
Regarding the "initial layer horizontal expansion", it's set to 0. I could "fix" this problem by setting this setting to -0.1, but I'm guessing something must be wrong elsewhere in other setting.
I'm attaching my project file in case anyone can take a look. Any help is appreciated!
Edited by DavidSL448
Oh, yes I did set that to 150. Guess I forgot about it, thank you so much!
burtoogle 514
Hi, please save the project file and attach to this thread so we can look at the settings you have used. Thanks.
