I don't know Hytrel, but these flexible materials are the only ones I know, that could help to be moisture proof. Waterproof is another requirement and they will not, because they are too hard, that's right.
I think it hardly depends on your model and what you want. Can you give an example what you want to do?
1
Smithy 1,116
You could try some of the flexible materials, like TPU95A from UM or Ninaflex which is much more flexible.
aag 5
Thank you! How do these compare to Hytrel, for which Ultimaker has just published a material profile?
http://www.dupont.com/content/dam/dupont/products-and-services/plastics-polymers-and-resins/plastics-polymers-and-resins-landing/documents/Hytrel_3D4100FL_NC010.pdf
I knew nothing about the Shore scale of hardness, but according to this synopsis: https://www.artmolds.com/shore-hardness
I am afraid that Shore 60D may still be too hard to work well in a waterproof joint.
