2 hours ago, gr5 said:Pay particular attention to faces that are gray versus white in sketchup.
You mean "pay particular attention to faces that are light-blueish versus white/grey". Right?
Thank you so much for such quick answers. I've been looking at it agin and so sorry but I'm still struggling.
I've attached the Sketchup file.
If you could advise any flaws if you see it I'd massively appreciate it.
When I did check if the model is solid it did come up as Group which I guess is the problem I just can't work out how to fix it.
Thanks again
Mike
SketchUp is not suitable for 3D-printing: it does not produce "solid" models, but a sort of "empty cardboard models" with gaps in the seams. Like paper models you glue together. SketchUp was only ment for visual representations of buildings, not for 3D-printing. It will drive you nuts, and you will waste huge amounts of time.
I would recommend you switch to another free program, such as DesignSpark Mechanical (for geometric models), or Fusion360. Or even Blender, if you need organic models, although Blender has a very high learning curve.
There are lots of good demos and manuals in Youtube. Watch a couple and see which interface and workflow appeals to you, and try that. It will cost you some time to learn, but you will soon earn that back.
Thank you all so much for your replies. I will give Design Spark a go as mine will generally be geometric.
Really do appreciate your help
gr5 2,331
Pay particular attention to faces that are gray versus white in sketchup. Read that part first maybe:
https://i.materialise.com/blog/3d-printing-with-sketchup/
