1 hour ago, smartavionics said:Do you have z-hop enabled? If not, perhaps you need it?
well, so the thing is I have this printer for like 2 months and I've experienced a bad case of stringing out of the box. I've been playing with every possible setting, reading everything about it online, forums, articles, guides, trying to fix stringing. changing temperature, retraction, coasting, calibrating filament diameter and extruder steps, nothing made a meaningful difference.
I gave up at a certain point and accepted that either the extruder or the filaments that I have access to are bad, until I tried to go back to default settings and disabling z hop, and for my surprise, no more stringing whatsoever.
after experimenting some more, I realized that the Z axis speed is too slow in this printer, it makes it impossible to break the filament string with a travel move because by the time the printer is done lifting the extruder for the z hop, the pressure relief from the retraction is over, filament has already started oozing again, and travel moves no matter how fast, are not enough to break the string anymore.
and not by coincidence, that's when I started having these knocking over problems. so basically I can have pancakes or spaghetti lol, can't get rid of both.
so that's why I was wondering if I could somehow get rid of knocking prints over without z hop, because I tried everything I could to get rid of stringing with z hop enabled and failed, now I'm trying to get rid of knocking over with z hop disabled
burtoogle 515
