SteveCox3D 80
This is pretty standard behaviour for the S5.
The S5 buildplate is quite heavy because it's a reinforced casting (and is much heavier than on an Ultimaker 2+ or Ultimaker 3).
Once the buildplate gets near the bottom stop at the end of the print the buildplate stops momentarily and then power to the stepper motor is cut. Because of the weight of the buildplate there's enough momentum, for it to freefall the last few mm onto the bottom stop. That's what makes the loud noise.
It's a little bit alarming, but not detrimental to the printer. You may not have noticed it at first because there's a little friction in the Z screw when everything's new that helps slow down that final drop. As everything becomes free moving then the noise becomes apparent (lubrication of the Z screw is a good thing but it does contribute to this happening).
The noise is still a little disturbing even after using an S5 for some time, but I don't worry about it because I know it's not causing any damage.
Hope that helps to put your mind at rest.
1
Garrett_Iverson 0
I have included a video of this issue in this Zip folder.
Thanks- Garrett
S5 issue.zip
