You can bake it on the heated bed or in an oven, both are possible. The time depends on how wet your filament is, overnight is a good starting point and then you will see if it was enough or not. I don't know the temperature for UM Nylon, but you should always stay below the glass temperature, otherwise, the filament gets soft and you can ruin the spool. As far as I know, the UM nylon has a lower glass temperature than other brands, round about 50°C, so I would start at 40°C for the drying process, but with lower temperature, it will take longer.
There also commercial solutions available like the DryBox, but it is nothing more than a normal food dryer which is much cheaper than the Drybox solution. But a heated bed and covered with a towel or an oven is also a way to go. When you use an oven, be careful and heat up the oven without the spool, because ovens mostly overshoot the target temperature when heating up.
My Polybox has humidity inside between 11% and 20% and that is fine. I also think that humidity below 50% is a way too high, especially for storing. I guess UM means that you print the material when below 50% but for sure not for storing. And when you have a long-running job, 50% can be too much. There is no other general rule how much humidity is acceptable, but keep it as low as possible.
Your hack box has maybe also too few silica packs, so you could give it a try to put 2 500g or 2x 250g packs in the box. The very small ones are not working fast enough and due to the reason your box is not airtight enough, too much air comes in and the packs cannot absorb the humidity quick enough.
Every box which is more less airtight and which contains enough or big packs of silica packs are ok and useable. The Polybox is just a commercial solution, which works well, but you can also make a box on your own to achieve the same result.
2
Smithy 1,134
You will have to bake the filament from time to time regardless of where you store it. Storing dry is very important, but not always to only way to keep the spools dry. So option 1 is something to do when your prints are not nice or you hear a sizzling sound.
Option 2 or 4 is a must-have in my opinion to have a consistent quality also for a longer print job. I prefer the Polybox, it is nice, small and keeps 2 spools in a dry environment. But it is nothing more than any other box you modify. I don't care about the NFC reader it does nothing else than select the material for you, so I can select it manually too. (But be careful, because then you have to choose the generic material in Cura and not the UM one, otherwise the printer thinks you have the wrong material loaded.) I also have no extrusion problems with the Polybox, you should just place the box in a way, that the filament goes in a "natural" way into the Bowden tube to avoid too much friction. I have mine on the floor beside the printer, without any problems.
Option 3 is not good. Without good ventilation, the air will get too hot inside and can cause problems with the material and stepper motors get too hot.
The Polybox is also nice to store the filament, so normally I don't put the spool back in an airtight container after printing, I just rewind the filament back and that's it.
But your drybox is also ok, so just use it, it fits perfectly behind the printer and you can use the NFC reader too.
KamalDahiya 0
Thank you so much Smithy for your consideration 😄
A little clarity on...
1. Can I Bake my Nylon spool on my ultimaker3 heat bed. (like Ultimaker website suggested for PVA). If yes, then what temperature and time for nylon?
2. Yes, I agree the Polybox would be better. But it will take few days to ship to my country and till then i have imp prints to give, So made this hack myself. But my question is the polybox claims to maintain humidity % below 10% and claims hygroscopic materials requires humdity% below 15 %. I am pretty sure my hack box is not keeping humidity% below 15%. it somewhere between 40-45%.
and on ultimaker website it says Hygroscopic materials can print upto 50 % humidity,
So what should be the humidity% maintained for prinitng Nylon an Pva ?
