Yeah, looks like you've been caught out by a bug in Ultimaker's brand new 'Unified' firmware. The 'Unified' being important because it's now been 2 and a half weeks since I've been able to X/Y calibrate either of our printers...
@piphil @Dim3nsioneer many thanks for confirming that this is a bug. Yes I am using the latest firmware. Hopefully this will be fixed soon or is there's any way to report this bug? I reckon somebody else has done this.
yep it's a known and reported bug, and as you mention there's an easy workaround, just push the material manually (open the feeder lever and just push filament to the end) and all is good.
Or you can just enter 0,0 for the calibration values as that is usually close enough for most things one would print. The units for calibration are 0.1mm. Unfortunately another thing about the upgrade is it seems to have changed the "old" xy cal values to random numbers sometimes as large as 30 (3mm).
Dim3nsioneer 557
Firmware 5.2.8, I assume? It's a bug and Ultimaker is working on a bugfix.
