I just did the solder solution for my a4988 stepper drivers on my U3Ext. I performed the hack on all 5 stepper drivers (x,y,z, extruder 1 & 2) because the issue is with the 2 missing/softer steps on all steppers, not just the ones that move the gantry/bed. How much those missing steps can affect the actual pressure through the nozzle is up for debate (may not affect it at all), but I figured might as well fix all of the similar devices instead of just x,y,z.
Seeing the heat sinks on the smoothers makes me wonder... Do the original stepper drivers also get hot with either the addition of smoothers or the "solder over the resistors" hack I did? I don't want to possibly butn them out because I didn't know.
neotko 1,417
I did at that time of test, also got a x/y shift months after. In the end like I say on the other post I just moved out to duet3d and been enjoying the quality of life of a proper 32bit cpu with trinamic steppers. Happy printer, happy life
RetromanIE 40
Ok, so I don't have any before and after pics ready at the moment. But the smoothers have definitely improve the print quality. The zebra stripes/salmon skin is gone completely on most prints and only slightly visible on some others. For the prints that you can still see the effect, I'd say it's a 90% reduction from before.
