2. How to calibrate the printing boundary? It is the result after I run the leveling wizard on a desktop pc. How can I move the print range back to the middle of the platform?
If you look at the print head - the nozzle is to the side. That is why it prints like that. That is normal.
I'm troubled by more and more prints getting the issue of layer marks and sandpits like pictures
You are less likely to get the horizontal layer lines with a .2mm layer print as this hides issues like this very well.
The horizontal lines are either over or under extrusion. The piece with only one line appears to be overextrusion.
There are 2 common causes: feeder or z stage. It appears to be a Z stage issue where you ask the z stage to move .06mm but it actually doesn't move at all or moves much less. That's why moving .2mm will fix this issue. Or even .1mm might be enough. There are many things that can mess up your z stage - the most common is the Z nut. The z nut (the huge nut inside the z stage) is designed to slide left and right a little. Sometimes when the Z screw rotates, the Z nut also rotates so the platform doesn't go down.
You can fix this by taking apart the Z stage and building with tighter tollerances. If everything is perfect you might be able to clamp the Z nut in place, but if the Z screw is warped a little you want to allow the Z nut to slide but not rotate.
Other possibilites is the feeder. For example if the filament gets tangled or stuck - then you get a bad layer with holes in it (underextrusion). Or if you print to cold and too fast you also get underextrusion.
SandervG 1,520
Thanks for your post.
The first 2 pictures are similar, is that on purpose?
The tool is meant to place the singular hole on the rod under your frame, and the other end with multiple holes on your rod that crosses your printhead. Put both tools on 1 end of the rod underneath your frame, so at the front and at the back for example.
It should indicate if your rods are straight or if they need any further calibration.
If one end is closer to the rod then the other one, you can open the corresponding sliderblock, loosen it so it has no tension and move the slider block in a way so the rod are parallel to eachother.
Regarding the prints, to me it looks like a problem with either the filament (inconsistant diameter?)
Or you could have some dirt in your nozzle that is occasionally interfering with your flow.
At what tension is your feeder mechanism? Can you sent a picture of the teethmarks in your filament?
