Posted · Cura 4.0 + 4.1 Beta -- bug with X Y Z scaling?
Hello,
I think I have found a bug in the way Cura scales the models.
When slicing one of these objects found here:
https://www.thingiverse.com/thing:2753230
I wanted to do an EUR version and tried to "scale X and Y to 99.57% and Z to 101.3%"
However whenever doing that it scales also other Axis or ...welll... hard to explain - generally scales incorrect values/axis. Try by yourself.
Tested on Cura 4.0 x64 for Windows and Cura 4.1 x64 Beta - the result is the same.
I worked it around by scaling with the size in mm instead of % even though it updates the percents in incorrect places (different axis) too.
    You have to uncheck the 'uniform scaling' checkBox below the x y z values if the scale is different on the various axes
    Believe me when I say that I tested it in various configurations and also selecting/deselecting various options.
    Scaling does not work correctly. Not with the object I have mentioned above --- try by yourself.
    Can it be that this might be related to the initial position of the object (e.g. keychain_10-krone_removable_token.stl) -- I needed to rotate it 90 degrees to put it flat on the bed).
    This is definitely a problem.
    Moreover I can confirm - with object that you don't need to rotate first (to put them flat on the bed) - scaling seems to work correctly.
    You seem to have done a lot of testing already
    Can you give us screen shots for the various cases where you see a strange behavior, and also those which have succeeded.
    As you have tested a lot of different configurations, do'nt forget to give us the values and params you have used for each test
    Here's the Evidence that I am not a derp.
    Open a file from the link I posted in the 1st post (or drag and drop it...) doesn't really matter.
    You see the object is initially not placed correctly
    So we are gonna rotate it by 90 degrees
    I have enabled the option to automatically lay it flat in Cura:
    Then we need to scale it accordin to the thingiverse comment --- 99.57% on both X / Y and 101.30% on Z
    But first let's disable the uniform scaling
    -> disabled
    Let's scale X to 99,57%-> enter 99.57 + enter - notice the size in mm changes for X
    Let's click on the Y percentage field and also change it to 99.57% + enter ---> size in mm for Y changes _BUT_ notice weird behavior in the Z percentage field (even though the mm size remained the same)!
    Then it gets even weirder when you click on Z percentage, change it to 101.3% (+enter) --- the Y percentage field runs amok (even though the mm size didn't change)-->
    This I could replicate in both Cura 4.0 x64 Stable & Cura 4.1 x64 Beta with objects that have an initial wrong position and need to be rotated to lay them flat.
    I _hope_ that this one replicable case will be enough to trace the bug down. Rest of the settings doesn't really matter and is not relevant for this case/bug.
    I think the bug is the following one :
    the textbox for the z porcentage is  after the y coordinate (on the 2nd line )textbox and 'vice versa' for the y porcentage and the z coordinate
    Might be, yeah... Not a biggie, but I do use the percentage scaling from time to time and this is making the life hard... but I never thought on narrowing it down... I just switched to other slicers (just to be sure).
    Now with a brand new printer I started to tune it & investigate this problem a little bit more... (registered just to submit the bug - pity there are any real bug-trackers ... at least not one I am aware of).
    You have not really try to find, in the HELP Menu there is a 'Report a bug" with a link to the relevant place !!!!
    So try not to give a judgement too quickly
    Ahhh... yeah I give you that one.
    P.S. No need to scream 🖖
    I do'nt scream as myself I did the same mistake but i think in a different 'spirit'
    Look at :
    https://community.ultimaker.com/topic/28025-bug-advice-slice-button-not-disabled-immediately/?tab=comments#comment-239483
    Posted (edited) · Cura 4.0 + 4.1 Beta -- bug with X Y Z scaling?
    I believe you mate. I just felt...well.... ignored (or taken for a derp/rookie) when you have asked me for printscreens, configurations and what felt like evidence even though the initial report was easily replicable etc. etc.
    But I've biten my lips, posted what I felt is necessary to prove that his is indeed a bug.
    BTW - this is feeling a little ... ridiculous to say it politely....
    When checking the github (in order to submit a proper bug report) I have found this old issue which remains still unsolved since... Cura 3.2.1 at least...
    https://github.com/Ultimaker/Cura/issues/4136
    I will provide the link to this forum thread... in the hopes that this might eventually help to solve it... Well... at least provided the repeatable case...
    Edited by SoniC_
    Look at your first post at the begining of this thread, and put yourself in the shoes of someone who hasn't worked on the subject. Is your description accurate, with the necessary information available.
    The sentence ' welll... hard to explain ' is far from useful to find the solution.
    Myself, I try to help to the extent of my knowledge, on my free time. The minimum for someone seeking help is to provide the necessary information so that those who can help you do so without spending too much time,
    I was going into this forum with the hopes that each and everyone who reads a "bug report" knows cura and is more or less an expert, and it is more than enough to provide an object with a link and a description that scaling by percentage (providing also the values) seems weird/doesn't work. It's more than uncommon, that rookies read the bug reports (And I again give you that one - I should have seen/found it by myself).
    Let's agree to disagree and hope that cura will be even better ;-)
    Ok nice end to this topic
          • Heart
        • 4 replies
