Thank you for the reply. I tried to print again with the cube towers and it is better, but still not clean or accurate enough to function. Should I make the towers wider? Or do you think something else might be a good adjustment?
My settings were:
.2 layer height
infill 30%
temp 195
speed 60
minimum layer time 10
everything else was standard
gr5 2,194
This is a common problem and super easy to fix. You need to either print 3 of these or if you only need 1 then put two towers - one layer taller than this part on either side. I have a cube.stl file I keep handy. You can click it and scale it to any cuboid shape in cura. So I scale it to be a little taller than my part and make two of them. Usually I do about 15mm on the base of the tower.
Having the printer go over to the other 2 parts gives this part time to cool down. Make sure your fans are working well also. I like to position the towers such that when it's printing one of them, the fan is blowing on the object to be cooled as much as possible.
