Posted
· bad results using PVA as support-material
what do you mean with prime tower?
the printer is standing on a not very stable desk/board, it is shacking a bit. (unfortunately this is the only available place for it right now) you think that could be the problem?
Posted
The prime tower is a little tower that prints between material change/layer change and will prevent polution from one material into the other. You can select it in Cura in the dual extrusion settings.
Framar 38
Never seen that before... Are you unsing a prime tower?
