14 hours ago, amfli1984 said:Im sorry what is a 3mf File again? Wow I just checked the model and it was sitting at.01 on the z axis, let me see if that helps. Thanks.
It’s a Cura project file. In Cura, use File.Save. It will ask you where to save the file.
You just need the nozzle closer to the print bed when printing the first layer.
To prove this you could simply push up on the bed or down on the print head while it prints the first layer and you will see it's fine. You only need to move them about 0.1 or 0.2mm closer.
gr5 2,331
Most likely your object - your STL file isn't sitting flat. But if you could upload a photo or even better also upload the 3mf file of your project someone could then help you.
amfli1984 0
