When you did the manual leveling, did you also disable the autoleveling? Or is it doing the autolevel before every print?
Are you using any z offsets in your gcode or do you use any post processing plugins?
I'm having exactly the same problem.
I did a couple of prints this morning and decided to update the firmware. Now on 5.2.11.
To be on the safe side I did a single auto-level then went to print the same object (a very simple disc with two holes in it). It did its usual little pile absolutely fine - but then nothing. The nozzle was touching the glass plate and nothing was coming out (because the nozzle was being blocked by the plate).
I've tried several attempts at auto-levelling since, with the same effect.
Something is very wrong.
I've also noticed that the progress bar on the base-heating and nozzle-heating doesn't work any more (although they're both heating up as expected).
Unfortunately, I don't know what the previous firmware version was, but I need to go back to it as a matter of urgency - is there a mechanism for reverting to my previous version?
This is on an Ultimaker 3.
Where you guys on 4.X before this? Or where you on 5.1 before this?
The upgrade from 4.X to 5.X is a two step process where you have to update to a "stepping stone" version and then immediately update to 5.X. You probably would have remembered that as you have to immediately do a second upgrade.
Some or all of the 5.X versions have a serious bug with the G92 command which, if you use G92, could cause what you explain. But Cura does not normally use the G92 command for the Z axis so it shouldn't matter. But many plugins use G92. Such as pause at Z possibly and there is some kind of Z offset plugin that definitely uses it.
I haven't updated in a while, but it could easily have been 4.x
All I know is I used the update menu option on the printer.
I also don't use any plugins.
Did you try a factory reset? Often these "distance error issues" after an update are fixed with a factory reset. At least with a UM2 this is true but I don't know about the UM3. I don't even know if UM3 has factory reset.
9 minutes ago, gr5 said:I don't even know if UM3 has factory reset.
It does :)
@bkirchman - manual leveling 1mm above the glass won't help much if it does an autolevel right after. Did you disable autolevel in addition to doing the manual leveling?
Okay - I heard from someone else that this bug is known and Factory Reset fixes the problem.
36 minutes ago, gr5 said:@bkirchman - manual leveling 1mm above the glass won't help much if it does an autolevel right after.
On a technicality, I would disagree about the manual leveling not helping.
In a broader sense, it is good to do a manual leveling periodically to correct for the buildplate 'settling' by way of many things. Basically, the more level the buildplate the less correction the active leveling process goes through.
Okay now I hear that "factory reset" does not fix the problem. Instead it's recommended that you set autolevel to "never" and then do one more manual level and you should be good. I only level a few times per year. The leveling doesn't really change. So once it's dialed in you are good for thousands of prints.
bkirchman 0
My firmware is the most up to date 5.2.11
