What about "painting" a glove onto her hands?
The first idea is of course latex, but that might *not* be a good choice because it could cause allergies, due to the enzymes it contains. And latex is said to shrink upon drying, so it might cause discomfort. I would not recommend this.
Maybe painting liquid and reasonable fast curing silicone onto her hands might work? Silicone is relatively inert chemically, and it is also used in dentistry, and in arts: most soft masks and fake wounds are made from silicone. Be sure to use platinum-cured silicone (=addition cured), not tin-cured because that is not stable and only suitable for single use. Be sure to check they are approved for use on the skin. And even then of course do a test on a very small spot to make sure it doesn't hurt.
You can find such silicones in special effects shops for film and artist accessories.
But silicones can be hard to remove from any model, due to their accuracy in duplicating shapes: they go into the finest pores, forming an airtight seal. So you might want to lubricate her hands with vaseline or another separator first. Try beforehand if the separator is compatible with the silicone: some products do inhibit the curing.
If the scan is accurate enough, you could try painting the silicone (or whatever else product you find) on the scan also.
If it has to be a two-piece glove, maybe you could mould-in some sort of clips or locks, to keep both parts together? Apply the first layers, let them half-cure (not liquid anymore, but still tacky), apply the clips or locks, and then apply more silicone until they are fully embedded.
Silicone comes in various hardnesses: from very soft like skin, medium like rubber bands, and harder like car tires. Some very elastic, some not. You can often combine them: soft where necessary, and harder where more support is required.
On Youtube, search for: body casting and mould making, or: creating silicone masks, or similar terms. There are lots of excellent tutorials. These are in the field of arts and dentistry, but the techniques may be usefull.
Of course, only use skin-approved non-stick silicone for mould-making and mask-making. Never use sanitary silicone, which is sticky, and is often quite agressive as it might contain vinegar acid: this could cause severy chemical burns.
nallath 843
Have you considered something like vacuum forming? You can get a lot more complicated shapes that way.
