Posted · Urgent help needed
My ultimaker 2 prints fine up to last few layers PLA.
Then suddenly it starts to print in random directions and the bed forces the printed part into the printhead and destroys the printed part.
This happens with all the things i have printed recently.
Please help ASAP
Thank you
    First look at your part in layer view to be sure these crazy movements aren't part of the gcode.
    But that is unlikely.
    More likely your um2 is getting errors when reading the SD card.
    1) try a different sd card.  Buy one if you don't have any spares.
    2) try cleaning the sd card slot.  I had to take my um2 apart and clean that slot very well.  I found a tiny hair in there (eyelash maybe) and after cleaning the random motions went away.
    You might be able to get away with just compressed air and not disassembling but that hair was very stubborn for me.
    Before you disassemble anything note that if you slide the bed up and look inside there is a semi clear part with a hole in it - you can see that if you put a small screwdriver in that hole and push it pushes the main control knob off.  That was the only tricky step for me.  once you expose the nut you can remove the nut and remove the screws that hold the cover on and remove the screws holding that small pcb down.
