Hi burtoogle,
IMO. This is a very good idea, as all of us want an object to be printed as fast as possible, -with as less as possible quality issues, right?
This is very interesting and can be a tool for increasing a quality of the printed object, decreasing overall printing time and as well reduce wear and tear of the printer (bonus -less maintenance)!
Resonance’s, harmonics, upper, lower and multiple etc. you’ll name it. This is a big issue in the mechanic world. And sure, -an FDM 2D printer is part of this “world”.
The good thing is that we have printers that’s built the same, -and will behave the same for a given model to print. So if we have the “resonance data base” (let’s name it so) for our printer, we can predict speeds to be used for a given model in order to avoid resonance issues in printing this model. This is sure some part of Cura -to some extent, I’ll think.
Well, this is a big issue for sure, and may take some time to do..
However, your idea using known print to analyze print quality of your printer is very much in time, I’ll say. Because such print test object do not take very long and will ease finding failures in our 3D printers. A good printer will always perform as expected.
If our own model is analyzed for best printing speed during printing, we will be the winners.
I would love to have such a firmware..
Keep up the good work.
Regards
Torgeir.
neute 15
there are smartphone apps that can measure sound frequency, which should make it possible to measure the print head's shaking frequency due to the sound it makes. I for example use such an app to tension my printer's belts to a certain value.
