I've been using 220 after getting some delamination at 200
I can't imagine you could go much lower if you are getting delamination.
Like Daid said your actual temp might be lower than your reading.
I used to print at the lowest temps but have raised mine to 210 now with more consistent results and better prints.
I have found Marlin firmware seems to give a much steadier and smaller temperature range which helps too.
I get a lot of warping though and although I've tried a lot of the things to help, which haven't been helping, I think it might come down to the particular filament more than anything.
Daid 304
Your 200C might be someone elses 185. Because not all temperature sensors are giving off the correct values. My temperature is quite spot on, and I normally print at 210C, while I have printed at 190C, it caused more problems then it solved. I can remove filament at 170C, so that's about my melting temperature.
If you want to print low, you need to go slower. Also, different cooling can help.
