On 1/10/2023 at 4:38 AM, mrgaryth said:I appreciate this is a bit old now but I am currently working on this mod due to my ultiboard dying. Where on the I2C header do EXP1 cables 4 and 6 go?
Edit:
I2C pins
0.0 = SDA1
0.1 = SCL1
@mrgaryth I created an adapter board to connect the ulticontroller to my BTT Octopus Pro, below is the design for where the I2C cables go.
EXP1 4 - SDA
EXP1 6 -SCL
The display, encoder, and SD slot are working in Marlin. On the start up the display shows static for a few seconds before showing data. I'm not sure if there is a way to fix that in software.
- 1
Top Posters In This Topic
11
7
5
4
Popular Days
Jun 21
3
Apr 29
3
Mar 30
2
Apr 28
2
Anthrix 11 posts
Porkpie 7 posts
nitrotech 5 posts
michil 4 posts
Popular Days
Jun 21 2020
Apr 29 2020
Mar 30 2020
Apr 28 2020
Popular Posts
Porkpie
thanks anthrix for your findings! to take things a little bit further, i did some work lately on this particular topic, and these are my findings so far: 1. have some freewheeling diodes added to
Porkpie
this is the final setup of the SKR V1.4 Turbo in my UM2+ chassis. without white cover and extra fan being off, the TMC5160 drivers easily reached 60°C @ 28°C ambient temperature, causing a hard r
Anthrix
So with a bit of modding cable for screen all working with skr 1.4 and ultimaker 2 controller screen, led, buzzer, sd card also working fine. Running marlin 2.0.x. Couple more bits and 32bit Ultimaker
Posted Images
michil 0
It seems that there was a problem with Marlin 2.1.1. After switching to Marlin 2.1.2 it is working again.
