Guest maht
QuoteRetraction is very quiet on the S3. And fast. You have to hold the filament just below the feeder to tell if it is actually retracting or not. Or use the color trick I mentioned.
Judging from the backplate in the photo, this is the Ultimaker 3, rather than the S3. Maybe @Dols can confirm as it's important when it comes to debugging.
Combing is indeed a good place to check. If the default profiles aren't working, you can try tweaking retraction distance settings so that retraction is extended by .5mm or so.
gr5 2,334
Change "combing mode" to "not in skin".
If you look at your part in PREVIEW mode and choose color scheme "line type" and check the box for "travels" (blue) you now get 2 types of blue lines - 2 colors - one color shows retraction moves and the other shows non-retraction moves.
You will see that with default settings there is no retraction for the layer you show in the picture above (bottom and top layers are called "skin").
What is combing? Combing saves a lot of time on a print - if for example you are doing infill you don't want it to retract hundreds of times as some stringing *inside* the part is usually fine. Unfortunately it is also enabled by default on top and bottom layers. Just change combing to "not in skin".
