Hi Geert,
I will check this with this (https://ultimaker.com/en/resources/52524-xy-offset-calibration) and this (https://ultimaker.com/en/resources/19953-aligning-the-axles) method.
Thank you for your input.
Hi Geert,
Hi again,
I was able to solve the issue with aligning the axles. Sadly following manual isn't available with pictures for the S5. Nonetheless the guide helped me.
https://ultimaker.com/en/resources/50679-check-for-play-on-axles
geert_2 543
Have you tried measuring if the X- and Y-axis of the printer are perfectly perpendicular? Maybe they are around 89° or 91°, instead of 90.0°?
