Just as a point of comparison, I printed the same STL using my Ender 3, eSUN PLA+, a CURA profile matched as closely as possible, on a battered and bruised magnetic sheet bed. The results from the Ender are baby-bum-smooth in comparison. You can still feel the slight roughness on the edges of each line, but it has none of the extreme banding and up-and-down undulation perpendicular to the lines.
I am sure there is something fishy with the results from the S3.
gr5 1,877
note to others - It was when I clicked the 3rd time on the photo that I could really zoom in quite a bit.
Like I think I said in the other post - it looks kind of normal. It looks like maybe some oils got on the printer or maybe you used glue stick and the glue is thicker or thinner in those areas.
It would be more interesting to see a photo of the bottom of the finished print but this looks pretty typical/normal to me for 3d printing.
prof_west 1
Thanks for the feedback.
I'm genuinely surprised that this might be normal. Running fingers over it, there really is a *lot* of height variation, and I find it so odd that the effect is so localised, so well patterned, and so consistent between prints. After months cutting my teeth on an Ender 3, I've never seen anything like this, unless I had something very wrong - plate height completely, poorly calibrated flow, gross over-extrusion, that sort of thing.
I do use glue stick, but I dissolve it in a spritz of DDH2O then smooth it down with Kimwipes to get a super-thin super-flat layer of residual glue. Glass plate was freshly cleaned with DDH2O then 99.9% isopropanol before both prints.
Maybe I'm TOO GOOD at 3D printing, and don't know anything other than perfection? Yeah, I don't think this is the problem either......
