In the upper right corner of Cura click "marketplace" and make sure you are on the "plugins" tab and install "Mesh Tools". Then restart Cura. Now right click on your model, choose "mesh tools" and first choose
"check mesh", then if that passes choose "fix model normals" and "fix simple holes".
gr5 1,968
if using blender you probably have reversed normals (or missing walls). You shouldn't be able to but unfortunately, Blender lets you set which side of a wall has plastic and which side has air (most CAD programs don't even ask or have the option to create non-solids but blenders lets you reverse these). Here's how to fix your model.
https://www.katsbits.com/codex/flip-normals/
