Hi DarRAven,
Cura do not want show this model due to some references moving the extruder far outside the printer area, this go down and up and start approx where your print fails. In S3D this can be observed.
Try to make a new download of the model again, try open the gcode file in Cura and if it open it is Ok.
If not do not try printing it. -Are you using Cura for slicing??
Thanks
Torgeir
Normally I don't use cura but for this time I used it and it showed up with these movement fails
So, what version of Cura did you use?
Is this gcode file the one on the SD card, -or is it from a "saved file" on the PC?
Have never seen Cura doing such an erratic movement outside the printing "box".
So if this is a copy from the SD card as @geert_2 assumed, this is probably your problem. This SD card/card adapter have had some issues..
Thanks
Edited by Torgeirerror in text.
tinkergnome 917
Okay Thank all of you so much I will change my sd card.
If you would have compressed air, also blow out the SD-card slots in the computer and printer. Often hairs or dirt get in there, causing bad contacts and thereby similar problems, resulting in corrupt files.
geert_2 543
I can't interprete gcode and can't verify it. But in Cura's layer-view you can see which traject the nozzle is going to follow. If Cura is at error, then you should see those erratic movements in the preview to. Before saving any gcode, you should always inspect the preview. Does it show those problems too?
I rather think that, depending on your machine and file-transfer method, the memory card is defect, or the file is corrupted, or the card's connector is dirty, or the USB-stick is defect or corrupt, or the communication gets interrupted or corrupted if via network or USB-cable, or the computer is too busy doing other things, etc. Something along that line of thinking...
