Before I upgraded my stepper drivers on my UMO, I added some rubber feet made from automotive heater hose. It was what I has on hand and it made the printer much quieter. A difference in print quality was not noticed. I printed some simple cylinders with a through hole for mounting. The OD is a slight press fit for 1 inch hose. Screwed them to the bottom. Pushed on 4 pieces of hose somewhat longer than the spacers.
Hi..
Yes, been using kind of same method, as a 1/2 inch thick "hard foamed" plastic (the withe one..) between the table and printer for a long time. However, as it become compressed over time it has to be renewed, -the kind I'm using. But it is insulate the bulling noise that's amplified when in direct contact with the table.
What I'm think about is a kind of "active vibration" system, that's sensing "hi impulse" movements that's make the build plate vibrate, I.E. when doing infill etc. IMO., there is two approaches to solve this, by doing it "almost" in real time or by analysis of the gcode file before printing, in order to adjust speed according to a known speed/movement table before printing -for this printer, or printer type..
Here is an example of a system that can measure vibration in X,Y and Z axes, using an accelerometrer ADXL326 and an Arduino compatible microcomputer, a Teensy 2.0 using an Atmel AVR microprocessor.
This is actually the hardware that could be used as a start..
Take care
Thanks
Torgeir
Edited by TorgeirTxt error.
I have used these for about 2+ years and have found them to work very well on my UM2+ - certainly reduce the noise etc. Design by @UbuntuBirdy who used to be on here.
https://www.youmagine.com/designs/ultimaker-2-2-damper-feet-12-55
I assume they would work on a UM3, but would be worth checking the dimensions of the grooves on the mounting area.
Edited by navigatorAdded designer info.
- 4 weeks later...
I've been using Sorbothane viscoelastic rubber half-spheres as dampening for my Ultimakers for years, and it really does reduce the noise quite a bit, with my own designed feets:
https://www.youmagine.com/designs/dampening-feets-for-ultimaker-2-3
Enigma_M4 125
I think the truth lies in between: having a sturdy solid table to put the UM3 on it, and using some rubber feet (like for example these: www.thingiverse.com/thing:3059433 ) will do the trick.
Regards
...and id could be a good idea checking the frame screws for tightness, as they also can come loose by vibration and time (I wonder why this is missing in the official maintainance shedule)
Edited by Enigma_M4Link to post
