Posted (edited) · filament extrusion slow but not zero
After ca 100 3D objects the filament extrusion slowed down. The transport at the other side of the tube is faster, as a result, the tube goes off, printing is discontinued. This is getting harder, elevated temperature did not help
(Ultimaker 2+, transparent PLA)
Edited by tilmanlampartter
    Posted · filament extrusion slow but not zero
    try to clean the nozzle using 'cold pulls / atomic pulls' (google), if that does not help the nr1 issue is wear on this part, you need to replace it occasionally, frequency varies with the type/temp of materials you print. if you only print PLA you hardly ever have to replace it.
    thanks, I may need to replace this part, I have already made atomic cleaning, tried lower print speed, elevated temperature, always same problems. 4 models were printed half then print was interrupted and the filament curled behind the printer
    so the picture does not look the same as my printer (ultimaker 2+) what is the part called? where can  I get it ?
    When doing an atomic pull, you can often see if that part is deformed: if the edge between nozzle and coupler in the pulled-out filament has a thick blob, it is for sure damaged.
    In the photos below, the bottom orange one looks pretty good: this is okay. The other orange ones are hard to say, because of the deformation due to pulling. The blue one starts to show a bit of thickening where the teflon coupler would be. But the white one at the bottom has a huge sort of "blob-ring": here the teflon coupler is totally gone and needs replacement.
    Ultimaker 2+ still has the same problem, I cannot use it any more - 6 months after purchase.
    Filament moves slower out of the nozzle than it is pushed into the tube. See above.
    According to devices here, I have made atomic pull about 10 times all together, i have replaced the teflon coupler (22EUR), I have replaced the nozzle (0.4 into 0.6), all this took me several days and it still does not work. I wanted to use the 3D printer for a teaching project at the university and for a master thesis, it is not the best advertisement if I am stuck here. There is already a delay. Wikth this experience, I would not want to buy a new one even if we had the money for it. (I do not have the full understanding whether officials from Ultimaker read these messages, if yes, the latter message is for them).
    Today I will ask for gurantee / replacement at Conrad electronics in Germany, where it was bought.
          • Heart
        • 4 replies
