9 minutes ago, D95 said:I started using pink aquanet hair spray back with my UM 2+ to get ABS to stick, and have migrated to using it even for my PLA projects.
Remove glass plate and clean with Windex. Dry whole area off well so no windex residue remains, or hair spray will bead up.
Soak the glass plate with hair spray THICK until a clear layer forms on glass. Wipe off corners where clips hold. Place the glass back in printer, and pre-heat the base plate to 60C until dry. Acts like a self leveling compound for the glass. Then run your print once dry in ~5 minutes. Have had zero adhesion issues, glass damage, or self leveling issues with my UM S5 or 2+. Do a fresh windex clean and re-coat with hair spray before any 2-3 day print. Worth the time. Buy the hair spray in bulk because you will use a lot once hooked. Good luck
You didn't get it. I am having the opposite problem.
Smithy 1,131
You want to apply a layer of glue on the glass, to proctect the glass. If you print on clean glass it can happen that you chip some small pieces of glass out of the plate. It happenend to me often when I forgot to apply some glue or something else. You can also try to use Dimafix, 3DLac or something like that.
Another solution is to use the UM adhesion sheets. It will not come off easier, but it will also protect your glass.
D95 3
