Duh.. an Ender 3 Pro has a flexible magnetic build surface, so no need for hair spray or other stuff to let the filament stick! Also no need to raise the flow-rate for the first layer...
Check this website: https://www.chepclub.com/bed-level.html
-- watch YouTube video & download gcode files for bedleveling! It is best to do bed leveling 2 times 😉
Use Cura with the default setting for an Ender 3 (Pro), later on you can change settings, first get the printer to work!
Don't forget to clean the build surface regular with isopropynol alcohol... 70% is enough, higher % will damage the build surface after some time.
Top Posters In This Topic
17
11
7
3
Popular Days
Aug 29
12
Dec 30
6
Feb 3
5
Jan 10
4
GregValiant 17 posts
Mari 11 posts
amalinahmad 7 posts
Fireowl87 3 posts
Popular Days
Aug 29 2020
Dec 30 2020
Feb 3 2021
Jan 10 2021
Popular Posts
sandman416
I have been living in this thread all weekend. I got the Ender 3 on Friday, built it Friday night (had my share of WTF moments) and tried the first print on Saturday using Cura to slice as the provide
Posted Images
GregValiant 1,317
OK, I will not say "Now before you stay bed leveling, temperature heating or bed adhesive."
Check your 1st layer height. I like .2mm but sometimes Cura will default to .28mm. I think that's a bit too much gap to fill.
Just before the line ";Layer:0" in your gcode file, add a line "M221 S115" to set the flow rate at 115%. You want to guarantee that the plastic gets smashed into the nice warm plumb build surface that has hair spray on it.
Search the gcode file for "Layer:1" and just before it, insert "M221 S100" to set the flow back to 100%.
I like to level the bed with parchment paper. It's only .06mm thick and nothing sticks to it. It's used to line oven baking pans. I find that I'm much more consistent than I was using printer paper.
