You would need to sit next to the printer and keep watching. My guess is that the bed is not perfectly clean, and/or the glue (if you use glue for bonding) is not spread equally. So the printed sausage does not stick perfectly.
In such cases, I have seen these printed lines lifting a little bit on the outer edge. And then, on the next pass of the nozzle in the opposite direction, they would be melted again and be pushed against the bed again. If the bed-adhesion is not identical everywhere, this could cause similar irregular patterns.
Filament with silver or glossy particles makes this much more visible, since the orientation of the filler particles changes, and thus their reflection. Mostly the fillers are flakes, little mirrors.
Printing thinner first layer lines might help. But then your bed leveling and bed flatness need to be very good.
You can see this effect to some degree in these photos too:
Framar 22
Hello,
Hard to say from a picture... I'm assuming the printer print these lines from one edge of the part to the other. If so, then, it looks like something was on the build plate when the first layer was printed and that first layer was not squish enought against the build plate.
I might be completly wrong.
