For this i use adaptive layers, with a minimum of 0.06mm. (this is the minimum i print)
These settings are (hidden?) under experimental. If you want to vary between 0.06mm an 0.2mm, set the normal layer height at 1.3mm and the layer max variation at 1.4mm. This is just an example, but it would be settings for a globe.
Can you change the layout of the parts?
For friction parts, i always try to print 1 of the touching parts without layers (Z flat)
For rounds i would print 1 horizontal an 1 vertical.
Ps, ironing is something to avoid in many situations, especially with fine layers.
1
GregValiant 194
And now you're learning differential calculus and why PI is a never ending fractional number.
At the top of the sphere the angle of a tangent line starts to approach 0 degrees. Cura considers the area under the nozzle as a rectangle with 90 degree sides. When it calculates a layer, it pushes the rectangle up against the side of the sphere. When it calculates the next layer it can't slide the rectangle over quite as far. That leaves a little gap that is your step. Lowering the layer height is all you can do. If the layer height was .00001mm you would still have a step. It would be a really small step, but it would be there. As the layer height approaches zero the step width approaches zero but it never can get there.
The same thing happens on inclined surfaces but the steps are all the same size and are all triangular when viewed as a cross section.
