Here is the project file
Carla_Birch 116
I have just sliced that STL in Cura with the ender 3 printer profile and it looks fine, i dont have a ender 3 so i can not test print, but all the gcodes fine so it should print fine.
Might be a good idea to try another sd card and reslice the file if you print via sd card just incase you got a problem with the sd card, as the file and slice from cura all look fine.
Do you have a photo of what was actually printed? STL-file is ok, no problems with slicing in Cura.
Will give it a go on my Ender 3 Pro, there are many settings you are printing with that are unknown to us... Wall Thickness, Bottom/Top Thickness etc.
Printer is running now with 0.28 layer height, 30mm/sec. 0% infill... I would suggest to print smaller layer height to get better result (takes a little more time to print)...
But you definitely need support to print it in this orientation.
Edited by Mari@Mari thank you so much. I'll surely give it another try.
Labern 774
Can you post a project file or screen shot of how it looks in cura, layer view?
