If you use a small gap (i.e. 0.1mm) you will find that the brim does still mostly touch the model but is easier to remove.
Ā
Surprisingly, it does still help reduce the model's corners curling even when there is a visible gap between the inside of the prim and the model perimeter. This is the model that inspired the brim gap feature.
Ā
Ā
Printed using PLA, I noticed that the corners on the side tended to lift from the build plate unless I used a brim but the brim was hard to remove without looking ugly so I tried using a wide skirt with a very small gap and it still helped reduce the curling of the corners. I am guessing that a brim helps reduce curling by reducing the temperature change between the layers at the edge of the model.
Ā
I have also noticed when printing PETG that corner warping is greatly reduced when the bed temp is increased so for that material using a high bed temp (at least 75 deg) and a brim with gap gives me little warping at the corners.
Ā
Ā
1
burtoogle 516
Try setting the brim gap to 0.1 or thereabouts.
sr1329 3
Thanks Iāll try that. Would it still adhere the model to the bed if there is a full gap?Ā
