I use Alibre for my CAD and have never had this.
Is it every Alibre stl or just one?
Can you share it a Robert suggested?
Which Cura version? I think the new 13.12 beta might have a bug not loading stl files if you launch them by double clicking (windows). If you open from inside Cura it works.
The 13.12 beta tries to open the file in an already open Cura window, if there is no window open then it opens a new window. Which works on my PC...
It does not seem to work for me. If I have 13.12 beta open and select and STL file from (Windows 7) explorer nothing happens.
I've tried on two different computers (both Windows 7 64-bit).
Strange, does the output.txt says anything? It's stored in the Cura installation directory.
Nope. output.txt is completely empty.
Try to open it in blender and reexport.
Or scaling problem? Maybe the model is there, but very small. Try scaling by 100 or 1000.
In my case it was a scaling problem. Everything I exported in Blender was opening without issue in Cura. However, when 13.12 arrived suddenly nothing opened. Following MatEngi's comment, I tried scaling it up and then I could see it. Turns out Cura 13.12 is bringing in STL files at 1/1000 scale for some reason now?
Odd, Cura does do some "magic scaling" when it sees objects that are way too big or small. But that's only if it detects an object that is larger then 10 meter or smaller then 1mm.
Can you email me one of this "none loading" models, then I can take a look at it. (at daid303@gmail.com, I will delete the model after looking at the issue)
IRobertI 520
Are you able to share the file so that one of us can try it as well?
