Had some bad surface artifacts with JD and lots of stuttering, mostly in curves. Maybe the "one segment" created by Arc Welder can help JD in the way it calculates the path. Maybe it will cripple the printer haha... Let's see.
Will compile a new firmware enabling Junction Deviation and try with Arc Welder. Get back in a couple of days : )
ahoeben 1,986
For the record, I have not.
Try it, and report back. I'm sure other users with printers supporting junction deviation will like reading about your results.
