Hello Torgeir,
good idea. It worths a trial and I'll check it when printing shells again.
For the moment I have overcome the problem as I changed the model and inserted a support for the shell as Geert advised, with a very small gap of only 0,2 mm. In that way the surface covered by the support is good and has some blobs only around the edges. It is easy to remove the blobs afterwards even with finger.
I've already broken two of the finished models and I've noticed something, which perhaps cannot be skipped. The detail body consists of three cylinders with different sizes. The connection between the cylinders is a weak point. That's because the cutting plane is parallel to the layers surface. I'm not sure if rising the temperature of the nozzle only for that 2-3 layers would do any difference. On one hand the higher temperature should stick the layers probably stronger but the material will be more rigid and not flexible at that plane. So at sudden start of rotation again can happen a debonding/cutting.
I believe that is a major question and has to do with the producers of the filaments.
Regards
Stan
Torgeir 242
Hi Stan,
Good progress.
I made quite a few test with your "test" model and found that, by just adjusting the "Z Seam Alignment" to:
"User Specified" and "Z Position" to "Back" you may have fare less blob on the surfaces of the model.
There is just a little you have to remove around the edges, but look much better IMO., in the preview mode using the "gcode" file that is ready to be printed.
This is the only adjustment I made to your file.
Good Luck
Torgeir
