I'm new to the S5. I have a Prusa Mk3S and I've also used the Taz 5 and the U-print.
I love the textured bottom surface that the Prusa textured sheet gives. I'm wondering if there would be any factors precluding somehow tacking a Prusa textured sheet onto the S5 glass plate. I've measured, and although the Prusa plate is smaller, it seems to be within the area of the 'probes' that the S5 makes for bed distance when starting a print.
Likewise, is there anything to preclude/prevent using those semi-reusable stick-on sheets, such as those commercially available or those that you get for free in some brands of filament?
Any thoughts about alternative build surfaces?
Thanks in advance.
gr5 1,517
Just take it off and measure it. It's probably an exact distance in cm.
An alternative is to use painters tape. It gives a nice textured bottom. Before we had heated beds we used painters tape. You can buy it cheap on the internet in very wide (e.g. 4 inch) rolls. I recommend washing the tape using IPA (isopropyl alcohol). Otherwise parts wont stick to it great. The IPA removes that waxy layer that keeps the tape from sticking to itself. It's very thin so it just takes a few seconds of IPA and tissue to clean. Also realize you don't need heated bed but I still recommend it. but maybe a bit cooler. Maybe 50C for PLA. Depending how big your part is. Parts that use more than half the length of the bed I'd stick with 60C.
