By the way, if you have a linux desktop (or even one in a virtual box), I suspect you will have better luck.
tinkergnome 839
47 minutes ago, Elkelthen said:What does this mean? How do I fix it?
Well... the error message means that the folder "google/protobuf" is not there or the folder "....../protobuf/src" is not part of the C++ include path.
"protobuf" is published here:
https://github.com/protocolbuffers/protobuf
2
Okay. I feel dumb now. I didn't read it all.
gr5 1,513
I'm pretty sure someone said you can't compile for AMD specific hardware? It has to be x86 or something? I think it was @ahoeben (I probably misunderstood - this is a vague memory from a few weeks ago). AMD should be able to work with 64 bit x86 code I assume. I mention this as I see these programs are in an AMD64 folder. Not sure if that is relevant.
Also @burtoogle might be able to help as he builds cura all the time (but on linux). Unfortunately burtoogle has been silent on the forums for 2 months. But he's still quite active over on his github. You might open an issue on his version of cura and ask him there if you don't get an answer from ahoeben. He's normally very helpful: https://github.com/smartavionics/Cura/issues
