23 hours ago, svandestaak said:Hi Maurosacchi. Personally, I would be looking at PP with glass/carbon fiber. Extremely strong and PP works well with liquids. Make sure when you print that the z seam alignment is at random. And I would also print it with 100% infill. Final version anyway.
If you do want to go for PP, make sure you use the adhesionsheet and/or pp-adhesion from Magigoo. Those are the only adhesion solutions which worked for me when I used PP with GF (30%): XSTRAND™ GF30-PP (Polypropylene + Glass Fiber) (crea3d.com)
Sounds like a very interesting project, SandervG forwarded this thread to me. 🙂
Thanks! Any specific extruder diameter to be used with this filament?
SandervG 1,522
Good questions! Hopefully you'll find some help here. I'll also share this with our product experts if they have any input.
GregValiant 1,492
These are just some random thoughts...
The typical printing materials are fond of water. I'm guessing that would be a downside so if you can get something with a low affinity for water, that would be a prime consideration. It may be why Delrin was picked over something like Nylon. A prototype for initial pressure testing could be made from something cheaper(?)
Among other things, "Layer Adhesion" will play a part in water-tightness. Maybe a coating over the print?
I would make the bottom of the vessel a dome. The print will be weaker than any traditional solid part. A domed bottom would enhance it's strength in at least that area. Taking that further, I'd think about an ovoid as well. Egg shapes bear up well to uniform external pressure. The inside could still be cylindrical.
Put the battery in and fill it with dielectric oil? I think any infilled volume would still end up near 100% infill.
svandestaak 9
Sounds like a very interesting project, SandervG forwarded this thread to me. :)
maurosacchi 0
Thanks for the suggestions. What coating do you have in mind? Epoxy? Is there a specific product and if yes, what filament should I use with it to achieve the end result I am looking for?
Unfortunately I cannot make the whole surface oval. I could make the bottom round though. It would not be possible to use it. This canister is placed on the waste belt of a diver, It would become too inconvenient with that shape.
