There's no mystery. They pop out of the slider blocks. There are I believe newer slider blocks although this is irrelevant. If your printer is still under warranty you should be able to get a set of blocks and belts plus instructrions for free. Even if outside warranty - possibly it's free. Contact your reseller. And they aren't that expensive either way.
Check for cracks on the blocks. Even if no cracks they are popping out too easily. There are temporary fixes like this one:
1
ccmaker2020 2
This happen to me this morning as I found the rods had fallen off and my print was destroyed. I placed the rods back in the bearing and while running a calibration test, I noticed the rods began to move out of place again. Any solutions to this?
