1 hour ago, Smithy said:
Hacking the firmware isn't for everyone. I don't want to do it when there's the risk of bricking the machine, then there's the possibility of problems when upgrading...
I put on some gloves, and take the hot plate out right away, and put the new glass in, speeds up the cooling down time 😉
Normally you should give the user what a user wants. If there is a request for skipping cooldown let us have it.
However you can skip cooldown from 60 degrees and down. But if you are above you cant. Makes no sense.
Please let us decide
16 minutes ago, thorsenrune said:Normally you should give the user what a user wants. If there is a request for skipping cooldown let us have it.
Agreed. Truly successful companies listen to their customers.
we need a skip cooling
Smithy 1,141
