@gr5 Yes, it may have to directly interface with the printer. I would like to add some sensors to the machine.
21 hours ago, gr5 said:You might do better to have this app install on the S5 which I don't think has lost developer mode yet.
Do you know if they are planning to deprecate dev mode for the s5 and other machines? It may not be worth continuing if it will just stop working one day.
Any idea about the terms of use regarding developer mode and APIs? I don't want to step on any toes
gr5 1,557
When I hear "plugin" I think "cura plugin" but this has nothing to do with Cura, right? It's basically an app that would install onto an S3.
I should warn you that I believe (not 100% certain) that developer mode on the S3 is disabled on the newer versions of the S3 firmware. Without developer mode there is no ssh/scp access to the printer. So I'm not sure how you would get this software installed onto the S3 - that may be quite difficult without scp/ssh access.
@ahoeben @robinmdh thoughts?
