Really need to update the printbedheating as alot of materials will require more heat then 98c° (running on UM3 ext)
Posted · Really need to update the printbedheating as alot of materials will require more heat then 98c° (running on UM3 ext)
I am wondering if there is a workaround that you have already done that allows me to upgrade my existing printbed that is reaching now max 98c.
Right now I am experiencing too much fails with PC and ABS and I am 100% sure that part of the problem is the printbedtemp.
Prints are comming out great until the print jumps a ceratain hight the warping starts and after 1 cm it becomes hilarious. So I have to get a workaround if I ever want to use theese materials in a good way.
So I am looking for a replacement of the existing printbedheater and or maybe to adapt an S3 printbed which would be already somewhat better with 130c° max heat
Any idea that is feasible would be appreciated..
Greetings and stay save!
Daniel
    What adhesion agent do you use? In case you use the glue stick and it is not enough you might want to try e.g. Magigoo Original for ABS and Magigoo PC for polycarbonate. Be aware the first one can adhere extremely well, depending on the filament brand.
    Posted (edited) · Really need to update the printbedheating as alot of materials will require more heat then 98c° (running on UM3 ext)
    Nice idea. I will try that because I was trying only with my yearly everytime glue UHU, which produced good results..
    Edited by HaryPlotter
    Just to let you know, just tried the Wood-glue and this ist atomic like!
    Really keeps everything there where it is supposed to go. Noneteless I will come to print ABS in a couple of days and I will report that as well...
        • 2 replies
