1 hour ago, geert_2 said:Did you switch off the cooling fan? Or set that at a very low speed?
For PET, which I think is very similar to CPE, I always print without fan if the model allows it, thus if it has no overhangs and no bridges. Otherwise I use the absolute minimum amount of fan.
I usually print PET on bare glass. (Although some say this is not recommended, as it might cause a too good bonding, and might chip the glass.)
Hi @geert_2 -
I will try disabling the fan completely. I have reduced the fan speed by 35% (off the already reduced speed in the Cura default profile), but have not reduced it to zero. My guess would be around 50% of normal fan speed. On this particular piece it should be a problem as there is no overhang. Ons the other two parts, there are 'roof structures' but I use normal supports for that. Should I still disable the fan?
I know I can obviously test these, but those are about 8 hours into the print and with the cost of CPE here locally, so would preferably try to avoid any misprints if possible 🙂
Kind Regards,
Friedl.
Edited by friedl_bassonadditional info
geert_2 556
