JohnInOttawa 104
There seems to be a number of threads now talking about print bed temperature for the UM3 and 3X. I wonder if the worldwide fleet is aging together and hitting the same issues in batches. We're seeing a lot of worn and broken capacitive sensor wire questions for example.
Would there be any interest in trying to consolidate the print bread temp stuff together on a topic? Maybe with a guide to diagnosing issues and possible fixes?
J
gr5 2,196
The second problem is probably related to your core - the teflon inside is probably too big of an inner diameter. If it's at all old I'd just get a new one. Or try your other AA core. Core's are considered expendable and when you think about it you spend MUCH less money on cores than on filament.
Do you have an IR temperature gun? How do you know it's too hot? This is pretty rare for the print bed - if anything it tends to be the other way around - increase resistance makes the temp sensor read too hot even though it isn't and the bed ends up being too cold.
