59 minutes ago, gr5 said:I suspect it's an illusion due to the fact that it shows the filament infinitely thin. Although it's possible you set "horizontal expansion" to a negative value.
Please share your project file: go to menu "file" "save...". The resulting file contains not only your STL but the scaling, positioning. Also it has your machine (printer) settings, your material settings, your profile used, and settings that you overrode. Please post that here.
I'm pretty sure it's the horizontal expansion. The second image clearly shows that.
gr5 2,071
baroberts 0
This is a part I was testing things on....but all my prints are doing this. Even the top pf the triangle is flattened
Test block.3mf
