Thank you.
I do not want to use auto level as well if I do not need to.
When I tried to push little bad downwards to make some room for filament to extrude out it just do not want to go out at all. Like it is stuck in the nozzle, but when I try to change filaments the nozzle do not look stack and it extrudes.
First image was cropped from video to show you distance that I created during print so it can extrude filament but it did not do it.
Second image is to show what the nozzle done to the paper, that we have on top of bed, after few prints. It leaved marks all over the the bed.
Last image is showing filament condition when I pull it out of the feeder 1. So as you can see the wheel clenches too much the filament and it leaves mark.
Rest of the sent images are showing condition of the the nozzle and the printing head, etc.
I tried manual leveling at least 20 times and I got always the same result. The nozzle is to close to the bed, so that the filament is not able to be extruded. But when I tried to push bed with hand to make room for filament it still do not extrudes out.
I also tried cold and hot pull to clean the nozzle and it went well. I think the nozzle is fine. But I am not 100% sure in that either.
I am not sure where problem is and I am trying different solutions for few days now.
gr5 1,606
wow!
I don't use auto level on my UM3. If I don't change cores it will hold perfect level for months.
It takes me all of 30 seconds to do a manual level now (yes, both cores) but even for a beginner it shouldn't take more than 3 minutes. The first part with the "1mm above" I just skip over those 3 points. Those are just to protect the nozzle hitting something. The only time I do that is when I've taken the bed apart and put it back together (once every few years I do that one one printer and I have 5 active printers).
Anyway here's my point: after you do manual leveling and it's printing the first layer, if it's not printing, push down on the glass with your finger. If it suddenly starts extruding then you levelled too close but you don't need to manual level - just turn the 3 screws tighter on the fly.
If it's still not printing, try pushing the bed up into the nozzle as well (just try it - sometimes it's too far and won't print well as the filament sticks to the nozzle instead of the bed).
