Thank you for your quick reply. Is there any way around this limitation ? By means of a plugin or similar ?
Or is there a way at least to save the project in such a way that it can be reopened with all funcitonality ? Because the way it is now is that when I reopen a project with all the local changes, it appears hardcoded. I cannot change the geometry nor the settings of the individual regions with different infill settings.
ahoeben 1,968
No, you can't, sorry.
That default set is hardcoded into Cura because without it you would get shells around the modified infill.
