Posted
· S5 huge layer shift .5" or more on top 20% of print on Y axis
It's pretty much always a loose pulley. Especially if it's just one shift and a large shift. But there are other causes (overheating driver, too much friction). 90% of the time it's a loose pulley. To prove it you can mark the pulleys and shafts with a sharpy and next time it happens see if the pulley slipped on it's shaft.
It's almost always the pulley on the motor (the hardest to get to). 2nd most common is the other pulley on that short belt.
Slide head back and forth in the Y direction and notice which stepper moves. The printers often come with a green and black hex driver. It's possible to get it into the set screw on the pulley if you slide the head around a bit until it lines up perfectly. Without having to remove the metal cover or anything else. Tighten the hell out of that set screw. It should be scary tight - if you were to use a little L shaped allen wrench your fingers should have red marks and pain afterwards. Very tight. Then get the other pulley on the short belt.
On April 20 - April 23 we will host the Ultimaker Transformation Summit. Come talk to us via Live chat and get inspired by any of our relevant presentations!
gr5 1,610
xtrude64 0
Ok, I will try that, thank you gr5!
