Hi @bassamanator.
First a small disclaimer: This is my first post and I'm fairly new to 3d printing and especially using an ultimaker.
I had the same problem with a cylindrical object and cura 4.8 a few days ago. There are a lot of settings in cura that can help with this problem. For instance: adjusting the Outer wall wipe distance, turn of wall overlap compensation changing the max comb distance without retraction or experiment with Z hop settings.
However, I just kept on having problems until I lowered the STL refinement in my CAD software (fusion 360). I do not now exactly why, but it did the trick for me. Al objects printed perfectly afterwards (with no loss of detail)
I hope this will help you,
regards,
- 1
Torgeir 248
Hi @bassamanator,
Well, this also looks like it could be an issue with your filament.
If the filament has attracted water, it can look pretty much like this.
Thanks
Torgeir
